DelCamper
Aug 13, 2012Explorer
The most innovative and simplistic energy storage system I have seen yet devised is pumped water storage. In times of abundance you move a volume of water from a low point to a high point. When needed you gravity feed that water to hydraulic turbines. The water is reused with evaporation being the loss.
The best system to transmit was to generate AC, boost voltage, rectify to DC, transmit as high voltage DC, covert it back to AC, reduce voltage to useable levels. This method increases the carrying capacity of existing transmission lines significantly.
Simple is best.
Simple is best.
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jul 01, 2026
