dockmasterdave's avatar
Dec 14, 2016
rv lot and septic
We are starting to consider buying some land in a rural area where staying in and leaving your rv is acceptable.
It would probably get used about 1 weekend a month.
Are there specific problems doing this, such as anything special I would need to do to maintain a septic system?
I was thinking I could put yeast in it every once in a while.
We're not sure about this yet, just figured I'd get some good advice.
TIA
  • You have to check state and county codes. In Alabama all you need is s septic tank with field lines. When I was in Mississippi we were required to have the septic tank and treating system. The treating system was nothing more than another tank added in the line where you placed chlorine tablets in it.
  • I'm not sure any answers will be valid to you, unless from poster from your local area.
    We've have a "vacation" septic system on our lot. Never any problems over 22 years. We have very good drainage.
    Friends of ours has same "vacation" septic system set up but in different part of the county and they have had many problems.
    So I think it depends on your soil/drainage. You can probably get better info from your local septic tank installers. Answers from all over North America might not do you much good.
  • There is a "balance" that has to happen with a septic tank that has to be maintained. Here's the balance:
    The tank has to be big enough and the leaching lines have to be long enough to accommodate the number of people using it.
    In order to keep the tank "healthy" it has to have the right balance of water intake, plus an intake for emzines to continue eating, or digesting, otherwise, they run out of food and die. Once dead, then the septic tank has to be started over.
    On the other hand, if too much is added to the tank too fast, the emzines (digestion) doesn't happen fast enough. Things don't break down, and next thing you know, your leaching lines get clogged up.
    My mother has lived in the same house for the last 72 years, same septic tank, but 2 leaching fields, because the original leaching field crossed over into a couple acres of ground that was sold so she had to have new lines put in on the existing immediate property.
    The only thing my mother has ever done to her septic tank is to squish up rotten tomatoes and tomato parts and flush them down the toilet. She claims, the tomatoes create the necessary emzines to keep the tank functioning. I was born into that house, and she's still living there. The septic tank was pumped only 1 time in 75 years, that was when a tree root grew into the line and it had to be opened up.
    If you are using the septic tank only once a month, you will not have to worry about anything for years and years and year! It will take years just to fill up the tank before anything even reaches the top to begin leaching. Just flush an occasional tomato down the tubes!
    (myself... at home... I use Rid-X about 4 times a year). Never had a problem with my system).
  • 55 Gal drum. Cut some holes in it. Attach 3 or 4 inch plastic (PVC or Black) drain lines with holes for drainage. Gravel around the drain lines. I am full time living in the RV and my drain lines are 30 feet long. No problems after 5 years.
    Only once a week you may not need a leach field. Simply cut some holes in the drum near the top and bury it with about 4 - 6 inches of gravel around the drum for drainage.
  • A septic tank and leachfield system would not normally require any maintenance at all - especially if you only use it one weekend a month. I would not use deodorants in the RV tanks though. In our neck of the woods, a permit is required for the installation.
  • I would think as long as you met the zoning code, there would be nothing further that need to be done. Sewer waste pretty much take care of themselves.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
