Jcs1382's avatar
Jcs1382
RV Service Centers... and Caulking
I'm fairly new to RVing and had thought I'd found a good local (San Antonio, TX) service center to help me keep my fifth wheel in good repair. I just had it in for repairs. They were supposed to check all seals and clean out old caulk and re-seal everywhere necessary. I was in a rush on pick-up, only checked the areas I knew were problems. Those were dealt with, though their invoice indicated they addressed far more areas than I found had fresh caulk. Later, I pulled out my ladder and really went over all the seams (I was doing slide seal maintenance). On my detail check... I found multiple areas where the old caulk was cracked & they did nothing.
I took photos and challenged them on the issue since I'd specifically told them I wanted to be proactive and I thought much of the 5-yr old caulk was going bad. Their response:
1) since I'd driven the RV (10 miles), new cracks had appeared due to road stress & flex
2) there is no reason to replace aged caulk, just wait for the cracks to appear and only fix the part with cracks
I say BS to both. But... I am new and may have an unrealistic expectation. I'm currently planning on dealing with the caulking myself. It can't be all that different from caulking traditional kitchen & bathroom borders and I have done that.
Advice / Recommendations welcome!
  • Agree with DutchmenSport on not removing the old caulk. Have always just cleaned and touched up. Also to afidel it is fairly common to just replace a single bad coil pack although I don't understand why the engines head was pulled for replacing the pack???
  • I am going along with the DIY crowd. I was not aware of the Winnebago caulking requirements for the roof to body seams and evidently neither were the previous two owners. Last raining season 2016/17, the roof leaked and I didn't see it until we pulled it out of storage and opened the slide. The white ceiling material was badly stained and the caulking an absolute bugger to replace. Plastic scrappers were useless and I used a utility knife, window paint scraper and hooked tool I made myself to remove the caulking from the fiberglass roof and aluminum body trim.
    Heat was of no use at all due to the location and after the caulk was removed the cleaning and drying and scrubbing and all those other adjectives were a pain. I'm not too spry, my 78th birthday will be Father's Day next week and I developed tendinitis due to the shape of the rungs of the ladder.
    Had I taken it to the local dealer or had the guys at the storage yard do it it would have been 8 tubes of caulk($12 to $15 a tube and all would have been self leveling and that is not what is called out in the Winnie manual. I know this because they caulked our last rig and didn't remove any old or damaged caulk.
    I can live with the pain in the heel but not with more leaks, it's done and it was done correctly. And it only took three and a quarter tubes of caulk.
    Transverse mounted V6, can't get to the rear bank without pulling the intake manifold (sorry, disremembered what had to be pulled, just remembered it was freaking expensive on the labor side)
  • I've never removed old caulk, either. I found Eternabond tape to be an excellent alternative. Just apply over the old caulk, making sure to use the proper tape width so that there is enough area for it to seal to next to the caulk( if I recall, I used 4" width tape). It's usually a permanent fix when done correctly.
