westend
Jan 16, 2017Explorer
Silicone is an excellent sealant when used in compression between two surfaces and not exposed to UV. Neither is the case when using to eliminate/****** leaks in RV exterior siding and trim. The added injury with silicone is that after the bond fails, it leaves a film that nothing else will adhere to.
I started using Geocel Tripolymer 2300 construction adhesive when I restored my RV. I now use it in a variety of projects for my customers.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
