Andonso's avatar
Andonso
RV water door key from older 88 RV
I recently purchased an older 1988 Class-B Okanagan motorhome.
The water inlet door key is missing.
I would take it to a locksmith, however the RV title was lost and I'm uncertain if the state it's registered will offer any sort of replacement title. (My state won't issue a bonded title unless there's an original title.)
The key lock doesn't appear to be a more common CH751.
I'm wondering if my only option other than a locksmith is to jimmy the door open, possibly breaking the door, which then would require replacement.
I have another 92 Class-C motorhome but none of it's keys even fit into the lock.
Below is a link to not very good pics of the keylock.
PICS OF KEYLOCK
  • Drill and replace the lock? It's probably a simple cam lock, they're not expensive.
    It will be cheaper than a locksmith and you won't destroy the door.
  • stick a flat blade screwdriver in there and a pair of pliers and give a twist.take vin # to dmv and ask what to do.
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 11, 2025
