hmknightnc
Jun 02, 2014Explorer
beemerphile1 wrote:
It won't harm anything but your 2014 should have a good charger built into the RV.
X2, why do you think the battery needs charging? While you are plugged in you are not actually even using the battery, the converter is providing all power (it's voltage is higher than the battery so the battery isn't contributing anything). Is your battery disconnect connected?
Looking for advice before your next adventure? Look no further.25,197 PostsLatest Activity: May 19, 2026
