Azatin's avatar
Azatin
Safety Chains
I need to extend my safety chains. My camper gvwr is almost 8,000 lbs. There are two safety chains, just like all trailers. So would replacing or extending each chain with 5,000 lb weight rated chain work? Would that mean that the total would be 10,000 lbs. since there are two chains? I know whatever I use to extend my chain will need to be rated at 5,000 lbs. Thanks
  • JFI....All trailers don't have two chains but one chain attached with a fastener in the middle of the chain. Some trailer required the single chain to be looped around the skid plate on the bottom of the tongue.
    Most trailers today probably have two chains.
    I use 3/8" gr 70 transport chain on my 10k car hauler (two chains attached to 1/2" loop welded to the bottom of the trailer tongue. And 3/8" grade 70 slip hooks with safety latches.
    One area I see some rv folks get in trouble is using a good chain with the proper load capacity but then use some type of "hook or latch" that doesn't have enough capacity.
    When the trailer leaves the ball its shock loads that can break a chain or a hook when it falls or a sudden left/right movement.
  • Bobbo's avatar
    Bobbo
    Explorer III
    If lengthening a safety chain, I would replace the entire chain. If shortening a safety chain, I would use a double clevis link. If the link fails, the original length safety chain will still hold. I would never use this to lengthen a safety chain because if this fails, you have no safety chain. (I have a utility trailer that I pull with 2 different vehicles. The safety chains are perfect for the truck, but too long for the minivan. I use these links when using the minivan.)
  • My opinion? Bigger, stronger, more hefty is always better. If you are switching them out anyway, go for all the glory you can afford. In the event you ever do need their service, you will have no regreats with your decision you make now.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
