davelinde's avatar
davelinde
[s/b Master Tow] Roadmaster dolly skid plate jumped... :(
I've got an old Roadmaster dolly we use to tow our car behind our truck. It's given great service for 3 years or so and we've towed at least 5K miles if not more.
Last night I was stuck in a parking lot and made a 90 turn a bit sharp (though still not as sharp as possible) and heard a loud CLUNK and then heard a guy in the lot shouting STOP STOP STOP.
It turned out that the skid plate had jumped the stop, over rotated and the fender put a healthy dent under the door. Worse, it was stuck that way and I could no longer tow... I was able to at least get off to an empty corner of the lot and barely able to unload the car. As I was pondering my plight a wonderful gentleman came over and we pondered it together. Using a ratchet strap, a tire iron and brute force we were able to pry the skid plate back up over the stops and rotate it back to center. I loaded the car again and pulled it another 500 miles without incident.
Looking at it this morning with the car unloaded, the skid plate is now bent up and sitting 2 or more inches above the slide pads (it used to sit on the pads).
Has anyone ever had this happen? Any idea what I did wrong? I know I turned a bit sharp, and I knew I was turning sharp when I did it. But I figured that only turning 90 would not be as tough as some of the 180's I've done OK before?
Aside from the "reminder" dent under the door and making an 18 hour trip into 19 hours - I'll consider myself fortunate it was not worse.
  • Today I met someone who had the same trouble with a dolly. It seems I was fortunate, theirs wedged in a manner that the only way to get it unstrapped was to cut the straps! I should be glad I could get my car off and back on again.
  • I'd recommend you work at getting it back to where it should be. JMHO.
    Not an unreasonable opinion either. However, I should note that with the weight of the car sitting on the plate it sits flat. To get it back to flat would require removing the center pin (seems not too hard) and bending the plate. It's pretty long, so getting enough leverage to bend it should not be hard either. Still, I'm wondering if it really needs a stiffener to stop this from happening again.
  • yikes.... thanks for proof reading me. That's what I get for trying to do several things at once. As the picture shows it is called a Master Tow (although I DID read the Road Master manual which is not helpful here). However now, reading the Master Tow manual I find the note "the ratchet strap CANNOT be over tightened"... so that theory is explicit not the case per the manual.
    So now I'm wondering about contacting Master Tow for advice here.
  • Yeah...good for you! OK.....I'd recommend you work at getting it back to where it should be. JMHO.
  • j-d's avatar
    j-d
    Explorer II
    Could help, to clarify the Make, Model, even Year if you have it. Some of your text says TOWmaster, text and title say ROADmaster, and the picture shows Master Tow. I'm not an expert, but I don't think Master Tow is a Roadmaster product. Clearer you can be, the more likely somebody's going to match up a similar product or experience.
  • ...so OK I actually COULD figure out how to add a picture I'd just forgotten that this forum doesn't allow you to direct embed or host here and I had to go look up my passwords to stash the pic to be read.
    Here it is - arrows at the new 2" gap and the vertical arrow shows the stop it jumped.
  • Read the "How to post pictures" and lets see your dilemma!
  • I just tried to add a picture of the bent plate to help... but couldn't figure out how to do that. I am wondering if I need to repair the plate somehow.
    I also have a theory that maybe I over tightened the wheel straps. I just re-read the Towmaster instructions and while they have plenty of warnings about UNDER-tightening, there is no mention of being too tight. When the straps are cinched up tight the skid plate did tend to bow up a bit in front. The front is where it hits the stops to keep it from over rotating. I guess that with the bow it was able to ride up over the stop, over rotate and the fender hit the car..
    Seems like a design flaw to me. I'm wondering if I need to pull the plate, bend it back to flat, weld up something to stiffen it, and maybe even weld something on top of the stop to make it harder for the plate to jump?
    Anyone ever call Towmaster? Are they helpful?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
