philandterri's avatar
philandterri
Screen removal
2006 Bounder 32W, how do you remove the screens on the sides of the bed and sides of the living/dining room slide?
  • Dave H M wrote:
    I think you push it one way or the other to the side and it will pop out of the frame. try pushing it in the direction that will allow movement.
    That's what I said too. Have to push it over to the side. They're spring loaded just like the slider except the springs are on the sides instead of the top.
  • I think you push it one way or the other to the side and it will pop out of the frame. try pushing it in the direction that will allow movement.
  • Okay, ours are crank out on each side of bed. Slide up/down on ends of the main slide out. These have a screw through the bottom of the inside frame going into the screw. As I recall, after removing the screw, you can slide the screen up and then over to one side to swing it in. Of course yours may be different.
  • Are they crank out, awning windows? On ours you have to remove the crank handle then pull down the spring loaded pins at the top of the screen and swing it in.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
