wny_pat1
Jul 29, 2013Explorer
You don't seal around your AC. It has a gasket that prevents the water from getting inside. Your AC gasket is about 1" thick. You set the AC down on it and tighten all four bolts, like you would a car rim - each a little at a time. You tighten it down so there is 1/2" between the AC and the roof. Do not over tighten!!!
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
