John_S2's avatar
John_S2
Seat Cushions are always sliding out.. Grrrrrrrrrrrrrrrr
It's a little thing I know but it really bothers me that our seat cushions in our 4 person breakfast nook or table are always sliding forward and I have to pick up the backrest part, that is connected by straps to the bottom seat, and slide the bottoms back against the backboard. Some of you folks must have solved this aggravation problem in some creative ways... I am anxious to get you ideas and suggestions. Our seat cushions are fabric covered over most of their surface but on the bottom seats about 2/3 of it is a vinyl. That may be adding to the sliding tendency.
Are there large velcro pads I could attach or???
The bottom seats project out about an inch or so over the edge of the bottom walls so adding a little board lip as a retainer would not work and would probably interfere with the legs of the seated occupants.
Once in a great while we do have to lay the cushions down on the table top to make a bed for the grandkids so I need a solution that is not permanent..
Looking forward to your feedback.. TIA !!!
  • Normal. Happens in your house also if you have the same type furniture and use it.
  • dalenoel wrote:
    Small piece of velcro under the cushion and on the wood will keep it in place.
    Ditto!
  • Small piece of velcro under the cushion and on the wood will keep it in place.
  • How about the rubber mesh used to line kitched drawers?
    That may have enough grip to keep the cushions from sliding.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
