Aron
Apr 03, 2016Explorer
Ron Gratz wrote:
A pair of 1000# WD bars (two bars rated at 1000# each) typically would be used with a tongue weight in the neighborhood of 1000#.
The amount of load applied to the bars is determined by how "stiff" the bars are and by how much you make them "bend".
The magnitude of load which could be transferred to the TT's axles would be determined by 1) the combined chain load applied to the two bars, 2) the effective length of the bars, and 3) the distance from ball to midpoint between TT's axles.
Assuming a load of 1000# applied to each bar, effective bar length of 30", and ball to axles distance of 200#,
the amount of load transferred to the TT's axles would be approximately 2*1000*30/200 = 300#.
Let me know if you have specific questions about how to determine trailer-induced load acting on the tow vehicle.
I'm always happy to crunch some numbers.
Ron
This is very helpful, thanks! It's been more than 20 years since I took a statics class, but I remember enough to be comfortable with the calculations. But I don't have much practical experience towing with a WDH, to know how much tension a hitch sized for 1000lb of tongue weight is supposed to provide. Also, I could use a check on my calculations, please.
So, here's my situation: my tow vehicle has a payload of 1364 lb (per the yellow sticker). Wheelbase of 119", and estimating 60" between the ball and rear axle.
I don't have a trailer yet, but I'm currently considering one with a dry weight of 5160 lb (GVWR of 6500 lb). I don't have good measurements on the distance to the rear axle. The trailer is 28'3" long, with an approximate 24' box, so I'm assuming (based upon photos) that the axles are centered or slightly behind the midpoint of the box, which would give a distance from ball to axle midpoint of approximately 195".
I'm thinking of purchasing a Blue Ox Sway Pro 10,000 GTW, 1,000 TW hitch (shipped weight of 96 lb according to the website). It appears that the spring arms are 29" long.
So, assuming that I can properly tension the spring bars to provide a full 2000 lb of load, that should generate approximately 297 lb of load applied to the trailer axles, correct? If I'm remembering my statics correctly, that means that 297 lb of load from the tongue would not be applied to the payload of the tow vehicle, correct? So even if I load the trailer to full 6500 GVWR, and load the trailer tongue to 780 lb (12%), I should not exceed the payload of the tow vehicle, correct? (1364-96-780+297=785) My family currently weighs 585 lb, so that still leaves me with 200 lb of payload buffer in case I can't tension the WDH fully, or if the trailer axles are further back than I think. And assuming that they grow another 100 lb or so, I would still have a 100 lb buffer. And that looks like a worse-case scenario, because I also wouldn't be fully loading the trailer to capacity.
Does all of that check out? Or is there a flaw in one of my assumptions? Thanks!
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
