naturist
Sep 17, 2021Nomad II
Sanitizer does nothing for iron deposits, which is probably what you have. Drain and flush should do the trick. If there remain stains in fixtures, oxalic acid will remove them. It is the primary ingredient in commercial rust stain removers. Chlorine bleach will not do the job, don’t try it as it will make things worse.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
