MFL
Sep 18, 2021Nomad II
I agree with above, likely iron deposits from well water at last CG. A friend purchased an older CG in the SD Black Hills that had this issue. It had a filtration system, that would fail (shut down), and all water, including the washers in laundry room would turn orange.
I would drain your tank, flush if possible, and time should remove any further discoloration. Using any type filter, is usually a good idea.
Jerry
Jerry
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 04, 2026
