Lynnmor
Sep 20, 2021Explorer II
AJR wrote:
Always use a filter on water going into the camper.
If I had iron deposits in my fresh water tank. I would fill the tank with filtered water. Open the drain and drive the camper on rough roads while it was draining the water. Hoping some of the deposits get suspended in the water and flushed out. May even do it twice.
Water containing iron cannot be completely filtered with conventional filters, they only remove the larger particles.
Driving around is a good idea if you can find a place where you won't splattering motorcyclists or affecting others.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
