Dutch_12078
Dec 08, 2020Explorer III
If it's only 30' to the septic tank, you can add a 4" clean out in the line from the house by just digging down to the pipe at the closest point to the trailer and installing a 4"sanitary 'Y' fitting. Run a short riser to ground level with a 4" clean out cap on top. If the new "dump port" is downhill from the trailer drain, just add enough sewer hose and an elbow to reach it, otherwise use a macerator as already suggested.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
