ugeesta's avatar
ugeesta
Setting the Trailer Brake Controller
When setting the trailer brake controller, how much pull is acceptable on the TV when braking? I ask cause I went through a set of trailer brakes in 1,600 mile, most of which were highway miles. The gain on the factory brake controller was set at 8. During the travels, I felt the trailer pull the truck when braking but ending recall the trailer tires locking up.
With the new brakes, I’ve lowered the gain to 7. In my short travel, I do t feel the tug on the tv when breaking and don’t feel pushed either. Just wondering if I should go lower on the gain.
The trailer is a 40’ 5th wheel toy hauler scaled at 15,000lbs being pulled by a 1 ton srw duramax.
Thanks
  • Lynnmor wrote:
    You should not feel much difference between trailer being towed on not towing. If you have been towing and feeling a tug, that is way too high. Since the trailer brakes have been abused, better check them.
    Sounds like he already replaced them.
  • You should not feel much difference between trailer being towed on not towing. If you have been towing and feeling a tug, that is way too high. Since the trailer brakes have been abused, better check them.
  • I mess with my adjustment until I feel the trailer is not pushing or pulling on the truck.
  • Way back when my dealer tested the setting on a gravel driveway. If the controller is set too high the wheels will drag on the gravel. We ended up with a setting of 6.5 which has worked since.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
