MFL
Sep 22, 2018Nomad II
I set mine to be correct for the approximate temp that I will begin towing. If cold at 7 am, much warmer at 3 pm, I adjust for my 10 am departure temp. Say tire pressure should be 80 psi cold, and 7 am temp is 40 degrees, but mid afternoon likely 75 degrees. I would set mine at 78 psi at 7 am temp, guessing 55 degrees, at my 10 am departure time will net 80 psi. Hope you understand, just my way, and works for me.
Jerry
Jerry
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
