Optimistic_Para
Sep 23, 2018Explorer
Tire pressure specs are COLD specs, which means they should always be set BEFORE you do any driving. I don't think the time of day is all that significant. If you are pulling out of the campground at noon, then go ahead and check them at noon, just before you start. See:
https://www.tirebuyer.com/education/tire-inflation-pressure-and-temperature#
As for inflating the tires to MAXIMUM pressure, well, the OP mentioned his fifth wheel trailer, and that's fine for trailers. I would NOT inflate the tires on my tow vehicle or motor home to maximum. The tire tread on an OVERINFLATED tire does not make maximum contact with the road, which means your traction, braking, and steering will be less optimal than it would be if the inflation were adjusted so the tire makes maximum contact.
For more info on this subject, take a look at the SmartWeigh program that Escapees runs. They have links to the Tire Load/Inflation Charts from a dozen or more tire manufacturers. Matching you weight to your inflation pressure will result in maximum road contact while maintzining safe weight carrying ability.
https://www.escapees.com/education/smartweigh/
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
