- ctilsie242Explorer IIDometic used to have an incinerator unit that used the vehicle's exhaust. I'm sure the tech is doable, but all the permits and lawsuit protection measures make it not worth it for most companies to even think about.
- Clay_SmithExplorerSewage elimination by exhaust heat may be the trick to keeping people from following too close behind you. (I know, the idea stinks)
Also installing a fuel filler neck into the black tank is a good way to get even with anyone that tries to syhphon your fuel. - keymastrExplorerAnd when they get clogged and need cleaned to function again they are not fun. Life on the water was better when we could just run the macerator overboard.
- wanderingbobExplorer IIThe newer Incinolet on boats require electric for about forty five minutes after use . On the boats that I ran they would heat when engine was running only . Did not use many amps
- Dave_H_MExplorer IIewwwwww, back where I was in 69-70 you put in a half barrel threw in some diesel and lit it up. :h
- valhalla360NavigatorDoesn't use exhaust but Incinolet does the same thing. Popular on commercial fishing boats because they run the diesels 24/7, so they always have electricity.
If you aren't driving and you aren't on shore power...powering them is a big issue. I don't think I'd want to run the diesel for 1/2 an hour after each poo. - steveksfcExplorerSorry, sounds like something we seen in another country, Not the job you wanted assigned to take care of.
- MrWizardModeratorTermaSan
back in the 70's
only lasted a few years, before it was no longer available
NOT new and NOT great - gmctoymanExplorerHad one, as delivered from factory, in an FMC. Worked well if you drove enough, if you didn’t you dumped.
Google FMC ThermaSan - down_homeExplorer IILet me know which route you are going to take so I won't get that perfume in the coach.
There was a reason S--- Burning detail was given to those that were the worse a--h---s.
It was intended, that sewage treatment plants would burn the sewage after drying, in very high temp incenerators. Would have been no smell when they were done and our rivers and streams would be polluted by various medications, sludge and bacteria and the like.
The Enviros said no because of CO2. Trees burn CO2, you know.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 09, 2026
