- tatestExplorer IIDepending on the application, shocks can be anywhere between 50-50 and 90-10, with the greater damping on rebound. Shocks stiff on compression make for a harsher ride, extension damping serves to limit oscillation and control the unsprung weight.
The only exception I know about was a drag racing front shock that served to hold the front end up for weight transfer to the rear, which had almost no damping on extension and was very slow to come back down. - _40FanExplorer
pronstar wrote:
Compression damping, and rebound damping, won't be the same.
For a cheap off the counter shock. The money that it would take to make it do what you would want to would scare away 99% of the people out there. - pronstarExplorerCompression damping, and rebound damping, won't be the same.
- Home_SkilletExplorer IIShocks are for controlling suspension rebound.
So, they are working correctly.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
