DownTheAvenue
Apr 20, 2020Explorer
BB_TX wrote:Chris Bryant wrote:
They are near worthless, as they will not work if the 15 amp outlet is GFI protected, which they all are required to be.
This answer is correct. Newer codes require GFCI outlets. And this device will not work with a GFCI since the common neutral almost guarantees the currents thru the two separate hot outlets will not balance with the neutrals back thru the respective outlet neutrals.
Might work in an older campground that has not been upgraded to GFCI.
YUP! This is correct!
Looking for advice before your next adventure? Look no further.25,189 PostsLatest Activity: Mar 27, 2026
