time2roll
Apr 20, 2020Nomad
dcmac214 wrote:Works fine for what it is.
How well does a dual-pigtail like this Camco item work for 15A plus 30A giving you a nominal 45A when they don't have 50A? Reviews at amazon etc are pretty good.
Does not combine power so you have 15 on one side of your panel and 30 on the other side.
Will trip a GFCI outlet.
If you are OK with these limitations then it will work well for you.
For most people a 50/30 adapter works just fine also putting the 30 amps on the full panel.
Looking for advice before your next adventure? Look no further.25,189 PostsLatest Activity: Mar 27, 2026
