Is it okay to plug 30 amp camper into 50 amp campground receptacle using an adapter? Is there any advantage doing so, if both 30 and 50 amp are available?
As others have said, it is OK to do. I have found a couple of times I needed to use the 50 amp even though there was a 30. Once when the 30 amp was wired reverse polarity, and more than once when the 30 amp connector was damaged enough that the 50 provided a more reliable connection.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
