Charley67ExplorerAug 26, 2020Shore power questionIs it okay to plug 30 amp camper into 50 amp campground receptacle using an adapter? Is there any advantage doing so, if both 30 and 50 amp are available?
BumpyroadExplorerAug 26, 2020could make adapters so that you could use either side of the 50 amps in case one side was overloaded.bumpy
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
Related ContentShore power questionNewbie power questionSolar inverter -- shore power questionShore Power QuestionNo power on outside GFCI outlet
