Charley67's avatar
Charley67
Shore power question
Is it okay to plug 30 amp camper into 50 amp campground receptacle using an adapter? Is there any advantage doing so, if both 30 and 50 amp are available?
  • I plug into the 30. If it feels loose, I use an adapter and plug into the fifty. You are checking both first, correct?
  • jdc1's avatar
    jdc1
    Explorer II
    Cummins12V98 wrote:
    You may have less voltage drop on the 50 vs the 30A.
    Or you could have more.
  • Yes it is OK. No advantage if you have 30 amps available.
Looking for advice before your next adventure? Look no further.25,165 PostsLatest Activity: Sep 20, 2025
