Skipg wrote:
What’s your thoughts about leaving a RV plugged in to shore power when not in use. I read it not good for the house batteries.thanks for your input.
depends on your battery charger. if it's a "smart" 3-stage charger with a float mode then, sure, no issues. if the batteries are lead-acid then I'd still check the water level once a month. but if you have an older "stupid" charger (my term) that just keeps pumping and pumping a charge into the batteries then, no. that will kill your batteries. our MH has AGM batteries and a "smart" charger. other than when it's in winter storage (no elec hookup available) it's plugged in here at home 24/7. when we snowbird in AZ the MH is plugged in for 10-weeks straight. no issues.
