SkipgExplorer IIDec 19, 2022Shore power questionWhat’s your thoughts about leaving a RV plugged in to shore power when not in use. I read it not good for the house batteries.thanks for your input.
K3WEExplorerDec 26, 202220 years ago, I cooked a set of batteries, when plugged in to the house. Thus, the rule is “factually real”New camper with one-year plug in- batteries OK.This is consistent with old chargers often being bad for extended use and new ones generally being ok.Double check the model if you have concerns.
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
Related ContentNewbie power questionShore power questionSolar inverter -- shore power questionShore Power QuestionNo power on outside GFCI outlet
