svt440
Sep 28, 2016Explorer
Bedlam wrote:
I suggested maximum pressure in the rear truck tires to eliminate side wall flex as a factor. If you find this helps, you can reduce pressure to closer to suggested inflation tables and see if squirm returns.
I do know there is something wrong with your match up and you need to make one change at a time to figure out the cure. If you still want a newer truck, don't let this stop you but that is a different issue.
Great point! Weak sidewalls caused some major problems back when I had a travel trailer, so I totally see where you're coming from. I'll definitely try the things you suggested, and as you suggested. Thanks!!
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
