rhagfo
Sep 28, 2016Explorer III
Bedlam wrote:mkirsch wrote:
You don't "need" a specific pin weight with a fifth wheel. Unless something is really really wrong with it, it should tow fine with almost no pin weight at all.
It's just that in an RV configuration, it is nearly impossible to do that. The axles tend to be closer to the rear of the trailer, and living space up over the hitch. 20-25 percent of the trailer's weight just tends to naturally end up on the pin due to design limitations.
Insufficient pin weight can cause fore/aft pitching in the truck and greater chance of jackknifing. At some point, acceleration and deceleration traction is also affected. I don't see any balanced teeter totter fifth wheels...
X2
That is the most irrational statement I have seen in a while!
Having near zero pin weight will lead to all kinds of ride issues, this is one reason I travel with a full FW tank! Increase my pin weight.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
