bgum
Feb 12, 2021Explorer
Disconnect and drain hose after filling fresh water tank. Operate off fresh water tank while freezing. Open cabinet doors to allow heat to get to pipes. Run water heater to heat water in tank. Make sure propane tank is full. Run small electric heater to supplement coach heater. Pull slides in if possible to use coach while in. Empty black and grey tanks. Camped as low as 12 degrees Fahrenheit.
26 is not really that cold but you never know , it is expected to be 15 here.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
