TheSeaPine_Owne's avatar
Jul 01, 2013
Should I be towing this? Real weights, real specs, real qu
The truck:
2008 silverado 2500 HD crew cab long bed 4X4 diesel Allison.
On the door:
GVWR - 9200 lbs
GAWR(FT) - 4860 lbs
GAWR((R) - 6084 lbs
The combined weight of cargo and passenger should never exceed 2181 lbs
In the manual under cc long bed 4x4 6.0L V8 4.10
Max trailer weight - 12,100 lbs
GCWR - 18,500 lbs
For fifth wheel trailer, kingpin weight should not exceed 3,000 lbs
The camper: 2011 sprinter copper canyon 31fwfsbhs
Sitcker: 9850 dry, GVWR - 12,300 lbs
Now the scale:
Weight of truck with full tank 100% loaded for the trip (we were on a week long trip)
Front axial 4875. Rear axial 3655 lbs. total - 8530 lbs
Weigh of truck and camper, again fully loaded:
Front axial 4880 lbs, rear axial 5920 lbs, trailer axial 9380. Total 20,180 lbs
I think I'm over my GCWR, but hit all the others OK. What do you all think about the safety of this setup? Have I exceeded othe limits?
The other trucks without CC or long bed or 4x4 have modest improvements to the Max trailer weight, but not so much GCWR in the manual. This is a fairly small 5th wheel! I see way, way, no way bigger campers on this same truck as the norm??????
What an I missing, is everyone over limit or am I making a wrong assumption. Am I OK with my rig? I couldn't get a smaller 5ther. The 3500's aren't that much better either in the specs...........
  • I might be reading it wrong, but it appears you are over the GVWR of your pickup by (10,800-9,200)1,600 pounds, which is too much for me.
  • Your over your GCWR a little but I don't think it's enough to matter. Especially since the axles (and hence the tires) aren't over loaded.
    I say enjoy the trip.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
