rjvis's avatar
rjvis
Should I go back to OEM size tires?
Hi, this is my first time on this forum, so I appreciate any help!
I am wondering if I should put OEM size tires back on my truck? It is a 2007 Suburban 2500, with the 6.0l and 3.73 gearing. It currently has 265/75/16 which came on it when bought the vehicle and they need to be replaced. I discovered the factory sizing is 245/75/16. We tow a 31’ BHS that weighs nearly 10,00 lbs when loaded which puts us right at the max for the burb. I haven’t really had any issues towing, but some hills are definitely a slow go. We live in BC so it’s quite mountainous!
What I’m wondering is if I would notice any difference in power if I go back to factory sizing? I don’t really want to as I find the 245’s just look a little small...
Thanks, Randy
  • You'll notice some, as you have effectively made a 4.10 geared rig a 3.95, a 3.73 a 3.55 geared rig. Also the 245 tires are about 5 lbs less weight than 265's. At least I noticed the difference in my 88 k3500 with a TBI 454/TH400/3.73, and my 96 K3500 with a 6.5TD/NV4500/4.10 gears.
    My 02 on subject!
    marty
  • The 265 & 245 are thread width in millimeters
    The 75 is the 'aspect ratio' ---- height of tire's cross-section to its width.
    The 75 means that the height is equal to 75% of the tire's width.
    The 16 is wheel diameter...16" rims
    A 245/75/16 does look smaller then a 265/75/16 cause of difference in width and sidewall (aspect ratio)
    Weight carrying capacity could be very different depending on the tires Load Index so check side wall for MAX Load/MAX PSI
    265's will be slightly taller, a little bit wider, have a bit more sidewall and will turn LESS revolutions per mile VS the 245's
    If you aren't rubbing side of tires when turning, whacking top of tire when going over rough roads/bridge transitions/speed bumps & haven't gotten a speeding ticket (245@65mph = 265@67.5mph)replace with another set of 265's LOL
  • You won't notice any difference in power with that small of a tire change. If you were running a lift and 38" tires I would tell you different. Keep the 265's.
  • If you change back you won’t notice any difference IMO.
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
