Devocamper
Jul 11, 2017Explorer
TC back to back propane tank question
We are out for the first time with the new TC and had to fill one of the propane tanks and found it to be a bit of a PITA on the mammoth with the tanks back to back rather than side to side which is how all our other trailers were where you never had to shut off both tanks to fill one . I was on the outer tank this time so it wasn't that bad but thinking ahead to having to fill the inside or back tank looks like I will need to remove both tanks and shut the propane off and shut off the fridge in order to fill that back tank , I thought about filling it from the front tank and just keep filling the front one but not sure about the adapters and hoses needed and if that would even work and would still require shutting down the propane , we often stay as we are now at the beach for three weeks off the truck so we do use some propane even more if I need the generator ,what do other do about filling that back tank any ideas are welcome
Thanks
Mike
Thanks
Mike
