skipnchar wrote:
You can try that but it would be a LOT safer to invest the half hours time and winterize the RV.
Space heaters are inherently dangerous but if you decide to use one, electric is safer than a fueled heater. Might be a better option to just turn on your furnace if you don't have time to winterize.
Good luck / Skip
Same here. Two jugs of the pink stuff and a half hour and I would be kicked back. Also i would never have something like that powered up just to charge batts. I disconnect the batt and hook a tender up to it if I get the urge. Just my thoughts.
