rockhillmanor
Jan 06, 2016Explorer II
EV2 wrote:rhagfo wrote:EV2 wrote:
I would winterized at 25 as that is a hard freeze if more than an hour or two.
Well put out a set of Ice Cube trays at that temp and you will still have water after two hours!
That and the water lines in a trailer are somewhat protected and will not cool to the outside temp as fast.
Did you miss the part where I said MORE THAN AN HOUR OR TWO?
I suppose you could set an alarm clock and check it at 4 to 6 hours???
I simply stated what I would do. No one is under any obligation to follow suit.
Get back to all of us when someday your less than half inch in diameter 'plastic' tubing water lines exposed on all surfaces freezes and blows out the cheap plex fittings.....not even close to comparable to a tray of ice cubes and what the resulting damage would be. :R
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 25, 2026
