DutchmenSport
Apr 17, 2015Explorer
You can use automatic dishwasher liquid. It's made to cut through grime as well as water spots and calcium build-up. You might want to dilute it enough with water (as it is usually very thick) so you can use it in a spray bottle. If not, just pour some on a sponge and wipe it on. You'll need to let it sit a while, but it will remove the lime spots wonderfully.
After you clean, get a squeegie and use it every time a shower is taken.
One other tip. After you clean the glass (even the walls), apply a coat of automobile paste wax before using the shower. Buff out the wax clear. Then use a squeegie and you'll always have a very, very clean shower.
I did this more than a year ago on my home shower, and I have not had to clean the glass since. The squeegie takes care of it.
But for your initial cleaning, Automatic Dishwashing Liquid (any brand) works very well.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
