Dave_H_M
Jul 23, 2015Explorer II
sch911 wrote:
We don't turn the water off. We have a sump pump system with a water powered backup. I do turn off the water heater, and the hot water valve.
We have a basement and a backup water powered sump pump also. The water supply comes in thru the basement wall. I arranged the plumbing so that I have a ball valve to shut off everything but the back up sump pump. The T off to the backup sump pump also has a ball valve in it for shut off if necessary. So when I leave I turn off the whole house minus the back up pump and then also shut off the two water heaters and the ice maker.
Also have a zone on the security system thsat has a sensor in the sump. Sequence goes like this:
Main pump goes south or power goes out
Water rises up and triggers the alarm
Water rises higher and causes the back up to take over
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
