et2 wrote:
teddodd wrote:
et2 wrote:
Ours can be turned on without the turn signal being used, but default to the turn signal when applied. I think I can shut them off, however it shuts the rear camera also. If I'm not mistaken there is a little access plate you can remove in the arm of the mirror. Take it off and you'll probably see the wires. Just disconnect and tape them off?
However it probably still won't show your toad when using the signal, the screen will just be blank.
I will want the back up camera to operate.
It will only be blank when you turn on the turn signal. It will go back to the toad after the turn.
Do you have the manual for the camera system? It might tell you how. If not call them and inquire if its possible to do what you want.
thinking of purchasing a color camera from tifffin so maybe can get some help from them.
