roadrider10 wrote:
For more real world towing experiences,I have a 2012 GMC Sierra 5.3 cc w/power tech tow pkg. 6spd/3.42 axle. We just returned from Florida towing about 3500 miles. Finally weighed everything loaded with full gas in the truck and all trailer tanks empty but all our gear loaded for a 3+ month stay. We are using a Reese dual cam hitch with sway control.
Trailer and truck 12,480 lbs. 15,000 GCWR
Truck loaded unhitched 6180 lbs. W/gear and 2 on board
Trailer loaded 6300 lbs. Dry wt. 5300 lbs.
Hitch 700lbs.
Truck payload rating is 7000 lbs.
Most towing was fairly flat through the south but did go up some significant hills in PA. and NY. The truck performed well and generally towed at about 2000rpm in overdrive at 60-62mph on flat ground. I did see 3500-4000 rpm on the worst hills when trying to hold 55-60mph. I am quite impressed with the new 6 spd trans. vs the old 4spd. I always used tow haul mode which did a great job keeping the engine in the sweet spot and automatically downshifting on descents. The 5.3 engine is not a torque monster but the 6 spd. makes the combination much better.
Towing mileage was 9.5-12.0 depending on terrain and wind. Non towing highway is generally 19.5-20 mpg. The 20"P tires do feel a bit squishy and I will eventually look for something with less flex. The shock dampening is also somewhat weak.
Would I use a heavier trailer with this combo. Probably not. I am pleased with my current arrangement and like having a little in reserve. I would feel comfortable towing long distances if you keep the weight at or below mine. After 14,000 miles I have had 0 issues so I am happy about that. The truck is very comfortable on trips but rather large/cumbersome when doing local errands. Try to use my wifes car more for local duties. Hope this helps.
I guess we both agree on how the rig works for us. My findings are about the same as yours and I agree that the 6 speed does make a difference. both of my other trucks were 4 speed.
Major difference with our rigs is the 20 inch tires, I have the 18.
Happy camping.
