scardillo59
Jul 05, 2017Explorer
Am I Calculating This Correctly?? Silverado 1500
First post so please be gentle...
I have a 2016 Silverado 1500 with a 5.3L V8 and the 3.42 gear box. Full crew cab, short bed and 2WD. The dealership I bought it from said the following:
Vehicle Weight: 4,700 lbs
Towing Capacity: 9,400 lbs
GCWR: 12,000 lbs
Tongue Weight: 1,200
We are in the process of purchasing a travel trailer that weighs 6,192 without any camping supplies or other stuff in it. If I am calculating it based on towing I come up with the following:
9,400 lbs-6,912 lbs(trailer),-550lbs (family weight),-1,000 lbs (supplies-we won't fill the tanks), -619 lbs (tongue weight) =319 to spare.
If I am using the GCWR of 12,000 lbs then I subtract all that and the truck and I am in the negative. Is that correct? I was going to use a WDH (Equalizer) as well.
Are the above numbers correct? If so, then game over on that trailer.
Thanks!
Steve
GCWR: 12,000 lbs
Thanks!
Steve
