TenOC
May 07, 2017Nomad
1. You do not want to charge the batteries TOO fast. It will boil all the water out. That is why I do not connect my generator 12 volt output directly to the batteries. I connect the 110 Volt output to my RV and let the RV charge the battery.
2. The "charger" (DC power Converter) in the RV should limit the charge rate. If it is an expensive one it is programed to adjust the charge rate so the batteries do not charge too fast.
3. My 750 watt small generator will recharge my batteries in about 2 hours (a tank of gas) it I run it every day I am off the grid.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
