MrWizard
May 07, 2017Moderator
800w should power a 30 amp converter
But it will take about 6 hours to recharge the batteries
Because the batteries are constantly tapering the charge
It won't be 30 amps for 4 hours
In many cases, with only two 6v
It won't be 30 amps for even one hour
In 3 hours you will get back to about 80 percent charge
You will return roughly 70 amp hrs, not 115
If your down 115, it will take approx 130 to get to full charge
From the converter,
some of the power is lost to the The rechargeg process
You can feel it, in the battery warning up
It is electro chemistry, and it is PITA
From the converter,
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
