tatest
May 09, 2017Explorer II
Maybe your peak charging rates will be 30-45 amps, but only for a while, because the charger will taper off currentv as battery voltage rises. If only the battery charger is connected, 800W to 1000W is certainly adequate, assuming there is nothing else connected to the 120V load. If you are charging using your DC converter/charger, you need to size the generator for at least the converter max input, which should be labeled.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 16, 2026
