turner66's avatar
turner66
Skylight and Dicor?
I had an odd thing happen today... Went to my RV (at storage lot) to do some prep for the Thanksgiving trip, and I had a puddle of water on my kitchen island countertop. Water was dripping from the skylight trim on the inside.
So up on the roof I go and intially couldn't find any obvious cracks. Upon closer inspection, it looked like there was a crack around the perimeter of the skylight at the point where the Dicor sealant overlapped the flange. Sure enough, upon pushing back the Dicor a little, it looks like the Dicor actually disolved the skylight clear plastic (or whatever it is). I checked the one over my shower, and it isn't like this. I'm going to order a new skylight, but as a temporary fix I cleaned the old Dicor and flange with acetone and laid on another bead of Dicor all the way around.
I don't recall seeing that these 2 materials are incompatible.
Anybody else ever see this?
Should I use something else?
  • handsome51 wrote:
    What is the number of the Sikaflex sealant to use. I checked and their are different types of Sikaflex sealant.
    When you purchase the tube of Sikaflex check the bottom of the tube for an expiration date. The tube that my dealer was going to sell me at past the expiration date.
    Don
  • Their are different model number Sikaflex caulking. What is the model number of the caulking to use on the skylight
  • I just went yesterday to a local rv repair company to check out my leaking skylight. I have a 2012 fw that I purchased "new" 3 months ago. One corner of the skylight was cracked, slightly under the sealant. Evidently one of the screws was tightened too much, causing the crack. We contacted the manufacturer and they are going to send another skylight, but will only pay for 1/2 hour labor. It seems that the sealant is a maintenance item and will require the most time. The repair company also suggested installing a metal frame under the skylight.
  • My Georgie Boy manual, under roof care: Old seals must be cleaned with mineral spirits applied on a rag to clean and reactivate the surface enabling the new lap sealant to adhere to the old. "Skylights (not Vents) require sealing with Sikaflex #221"
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
