Missionstreet's avatar
Dec 31, 2022
Slab sinking
I have a relatively new concrete slab that is about 23 by 13'. It is built on a bit of a grade with coordinated drainage pipe underneath.
It really is two pieces, 12x13 each. I noticed the side closer to the slope sunk about 1/4" to *gasp* 1/2" near the center where they meet after backing up into it and then changing direction again. (There is a perpenducular crack in the center to so it isn't sinking evenly)
Any thoughts?
  • I had my driveway raised by the injection method. Very happy with the result, and it was a lot cheaper than I expected.
  • A couple potential issues:
    - The base wasn't well compacted and now it's compacting. As long as it stops and it isn't pooling water badly or otherwise causing problems, I would just live with it. If it gets bad or otherwise starts bothering you, yes, you can have a residential paving company come out and use injection to compensate for the sinking.
    - How thick is the concrete? 4" thick and you can expect a 12x13ft flag to crack. There's a reason sidewalks typically have a 4-5ft joint spacing.
    - Are there any signs of water washing away the base material? If yes, you need to stop that or it likely will continue to get worse.
  • Sure a little uneven don't bother me. As long as it's not going to move enough to cause issues.
    I have heard of polylevel something. I think foam injection that lifts concrete? Maybe cheaper than other alternatives?
  • Can you just live with it? It might be pretty pricey to correct.
  • You can compact the ground until you are blue in the face and you won't reach 100 % compaction. The ground will still settle! The slabs should have been pinned together to eliminate uneven heights or seperation. Good luck, it will probably keep moving.
  • I would assume the base was not properly prepared. What does the concrete contractor say?
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 22, 2026
