SAYJACK's avatar
SAYJACK
SLIDE OUT PROBLEM
My slide out is not closing properly. Plenty of info on left to right misalignment but my problem is top to bottom. When the slideout gets about 8" frpm full close the top stops but the bottom doesn't.
I belive it's a Lippert electric slide mechanism. I can't even determine how the top is operated in conjunction with the bottom.
  • First off you got to know what slide system you have. Cable? Schwintek? Something else? If it's Schwintek and it's off 8 inches then got some serious issues. If it's cable then you might just need an adjustment. If it's hydraulic/electric you might have something blocking the top from coming in.
    For future reference you might want to check in which forum you're posting your question. Currently you're in the Forum Posting Help and Support when you should be in Tech Issues.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
