machunt's avatar
machunt
slider screen replacement
I need to replace my slider and stationary piece on my screen door. Measuring the opening 12tall x 26 1/2 wide. i found camco part 45591 but it says slider is 11 1/2 tall. anyone have to do this
  • I've yet to find the appropriate size plastic slider or panel to fit the screen door on my 99 Southwind Class A. Twice now I've had to buy (at Camping World) the larger size (panel and slider) and then cut it down with a sharp box cutter (knife) and straight edge to fit. A little sanding on the rough edges and then it works fine. Nothing's simple anymore.
    Chum lee
  • Never replaced one, but when i go to Amazon they list it as 18 x 12.1 x 0.8 inches. If you have Prime you could order it and just return it if there is a problem.
    Amazon
