BrianDD's avatar
BrianDD
Slow draining sinks & shower
Our sinks & shower drain extremely slow with the grey water tank drain is open. However, if I close the drain valve water in the sinks and shower drain normally. I have checked the air vent on the roof, it was clear
Baffled?
  • mrgreetis wrote:
    I think Kyle86 was talking about the dump valves - black tank and grey tank. The stink was able to move from the sewer connection thru the traps and into the camper. It is best to keep them closed until you are actually ready to empty the mostly full tanks.
    Thanks
  • Thanks for all of your replies. I am going to try what has been mentioned. However, as all drains are slow my feeling right now is that the grey water stack is partially plugged.
  • I think Kyle86 was talking about the dump valves - black tank and grey tank. The stink was able to move from the sewer connection thru the traps and into the camper. It is best to keep them closed until you are actually ready to empty the mostly full tanks.
  • kyle86 wrote:
    I learned the hard way not to camp with both valves open. First 2 nights we ever slept in a camper and the smell was horrible!!! I finally figured the sewers were using our rv as a vent and the poo poo aroma was coming up through our sink. Closed the valves and the next night was much better!!
    Excuse my ignorance, what and where are these 'valves' you're talking about?
  • I learned the hard way not to camp with both valves open. First 2 nights we ever slept in a camper and the smell was horrible!!! I finally figured the sewers were using our rv as a vent and the poo poo aroma was coming up through our sink. Closed the valves and the next night was much better!!
  • momentum rv wrote:
    Typically only black tanks have vents through the roof. Gray tanks use AAV (air admittance valves) under sinks etc.
    If the valve is stuck or ?? it's hard for air to get in to help drain and as RVPAPA said you may be pressurized which will also hold the valves closed not allowing air in.
    Hope that makes sense
    Grey tanks have roof vents also...even with AAVs
    OP........
    For a 'test'
    Make a 'P' trap in your sewer hose so that it has a low spot that traps water.
    Open grey dump valve
    With the low spot full of water....fill sink and then try draining it.
    'P' trap in sewer drain hose prevents vapors etc from CG system to come up into your grey tank.
    Personally........I only open grey drain when dumping and that is will full tanks and afterblack is dumped
  • Typically only black tanks have vents through the roof. Gray tanks use AAV (air admittance valves) under sinks etc.
  • I'm going to throughout another guess, like "Tin Pusher" did. It might be that your roof vent is plugged, causing differences when the valve is open vs closed. Just something to check.
  • Baffled?
    Not really. You are probably serving as a vent for the campground when the valve is open, which gives a slight positive pressure in the grey tank.
    Two ways to fix. Close the valve or put a 3or4' vent for the tank.
    This is the main reason that you (not you personally} sometimes get that 'outhouse aroma near the RV.
    Art.
  • Well, total guess: With the tank valve open, the tank draws air in thru the vent easier than drawing liquid thru the traps.
    Doubtless someone will set me straight :)
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
