treyster's avatar
treyster
Sink-shower drain question
Kinda new to this. My TT is a year old,just getting around to using it. My shower and sink drain into one pipe that goes into my rear gray water tank. When I turn either of them on, water backs up and stands there. As soon as I go outside and pull the gray tank slide to drain it the water drains out of the sink. Any ideas?
  • Contace the dealer. It is always possible the factory simply forgot to add a gray tank vent
  • Thanks everyone. There's one vent on the roof. Am I to assume the black and gray tanks share it?
    The gray tank and black tank are about 3 ft apart and the roof vent is offset on the black tank side. I don't see how the gray tank vents to the roof
  • Another good example of when you buy a new RV immediately take a shakedown trip and use all the systems hard. Then seek out a heavy rainstorm.
  • Try opening the dump valve, then go up on the roof with a hose, remove vent pipe cap and see if water will freely go down the pipe without backing up. Have a helper check to see water isn't backing up into the shower or sink and if it flows out the dump outlet pipe (may take a few seconds or more to come out) just in case.
    There should be a one-way air admittance valve (AAV) under the sink which allows air to be drawn into the holding tank even *if* the roof vent is plugged. Check to see if the AAV is working and replace if needed. These do sometimes stop working.
    The diagram below is a generic layout of the grey water piping that gives a basic idea of what the piping is like. (It's from Australia, ignore note on trap under shower as they are a requirement here and each sink & shower/tub must have it's own P-trap here). You can see that a plugged roof vent would still allow the tank contents to drain, although maybe slower. If the roof vent is plugged, water draining into the tank would tend to pressurize it and cause water to back up into the sink or shower. P-traps that will be under the sink & shower are there to prevent tank odors from directly venting inside and aren't affected by water flow direction but could be sucked dry if an AAV isn't working.
    It does sound like the vent pipe has dropped. If you remove the vent cover on the roof, you should be able to see the ABS at roof level. The pipe could have an offset between the roof and tank though. Sometimes you may find the pipe accessible in a closet or cupboard (like in ours). Providing you can draw the pipe back up to roof level where it should be, try and find a spot somewhere between roof and floor level where you can use a clamp or strap to secure it.
  • Go up on the roof, take the vent cap off and look. You could try running a snake down the vent to be sure it is not plugged. Also you could try lifting the vent pipe and see if it moves.
  • I bought it new last year. I figured it's a venting issue of some sort. Does the fix require removing the gray tank or is there a workaround.
  • would be tempted to check the roof vent for the tank, could have a test cap over the end, or plugged up..
  • Is this a new or new to you used?
    The problem is the vent pipe has probably dropped into the tank. Build up of pressure will cause slow drain or no drain.
    BTW, if your in a dill hookup site you can leave the gray tank valves open. Just never leqve the black tank valve open except to dump.
